Liste des messages qui peuvent s'afficher sur l'ODB
Contact :
Récapitulatif dans l'ordre alphabétique :
ACTIVATION DU REGULATEUR IMPOSSIBLE
AIRBAG LATERAL DEFAILLANT
AIRBAG PASSAGER NEUTRALISE
AIRBAG(S) DEFAILLANT(S)
AIRBAG(S) OU CEINTURE(S) DEFAILLANT(S)
ALLUMAGE AUTO PROJ. ACTIVE
ALLUMAGE AUTO PROJ. DESACTIVE
ALLUMAGE AUTOMATIQUE DES FEUX ACTIF
ALLUMAGE AUTOMATIQUE DES FEUX DESACTIVE
AMPOULE FEUX DE POSITION DEFAILLANTE(S)
AMPOULE FEUX DE RECUL DROITE DEFAILLANTE
AMPOULE STOP ARD DEFAILLANTE
AMPOULE STOP ARG DEFAILLANTE
AMPOULE(S) ANTIBROUILLARD DEFAILLANTE(S)
AMPOULE(S) FEUX DE CROISEMENT DEFAILLANTE(S)
AMPOULE(S) FEUX DE ROUTE DEFAILLANTE(S)
AMPOULE(S) STOP AR DEFAILLANTE(S)
AMPOULES FEUX DE RECUL DEFAILLANTES
AMPOULES STOP DEFAILLANTES
ANOMALIE ANTIPOLLUTION
ANOMALIE BOITE DE VITESSES
ANOMALIE ESP
ANOMALIE PORTE DROITE
ANOMALIE PORTE GAUCHE
ANTIVOL ELECTRONIQUE DEFAILLANT
AUCUNE ALERTE PRESENTE
AUCUNE CEINTURE PASSAGER AR BOUCLEE
AUCUNE LAMPE GRILLEE
AUCUNE PORTE OUVERTE
AUTO-VERROUILLAGE DES PORTES ACTIVE
AUTO-VERROUILLAGE DES PORTES DESACTIVE
BATTERIE DE SERVICE FAIBLE
BOITE AUTOMATIQUE DEFAILLANTE
BOITE DE VITESSE DEFAILLANTE
CAPOT ACTIF DECLENCHE
CAPOT ACTIF DEFAILLANT
CAPOT MOTEUR OUVERT
CAPOT OUVERT
CAPTEUR DE CHOC DEFAILLANT
CAPTEUR DE LUMINOSITE DEFAILLANT
CAPTEUR DE PLUIE DEFAILLANT
CAPTEURS PRESSION PNEUS MANQUANTS
CEINTURE CONDUCTEUR NON BOUCLEE
CEINTURE PASSAGER ARD BOUCLEE
CEINTURE PASSAGER ARG BOUCLEE
CEINTURE PASSAGER AV NON BOUCLEE
CEINTURE(S) BOUCLEE(S)
CEINTURES PASSAGERS AR BOUCLEES
CEINTURES PASSAGERS AR GAUCHE ET CENTRAL BOUCLEES
CEINTURES PASSAGERS AR GAUCHE ET DROIT BOUCLEES
CHARGE BATTERIE DEFICIENTE
CIRCUIT DE CARBURANT NEUTRALISE
CLIGNOTANT(S) DEFAILLANT(S)
COFFRE OUVERT
CONDAMNATION AUTOMATIQUE DES PORTES ACTIVEE
CONTROLE AUTOMATIQUE DE L'ENTREE D'AIR.
DEMARRAGE IMPOSSIBLE DEBLOQUER DIRECTION
DEMARRAGE PROLONGE EN COURS
DIAGNOSTIC EN COURS...
DIAGNOSTIC OK
DIAGNOSTIC TERMINÉ
DIRECTION ASSISTEE DEFAILLANTE
ENTREE D'AIR EXTERIEUR FORCEE
ENTREE EN MODE ECONOMIE D'ENERGIE
ESSUIE-VITRE AUTOMATIQUE ACTIVE
ESSUIE-VITRE AUTOMATIQUE DESACTIVE
ESSUYAGE AUTOMATIQUE ACTIF
ESSUYAGE AUTOMATIQUE DESACTIVE
FEUX DE STATIONNEMENT ACTIVES
FREIN DE PARKING DEFAILLANT
LA PHASE DE DEMARRAGE A ECHOUE
LA PHASE DE DEMARRAGE A ECHOUE (CONSULTER LA NOTICE)
LAMPE(S) GRILLEE(S)
MODE ECONOMIE ACTIF
NIV. CIRCUIT REFROIDISSEMENT INSUF.
NIVEAU ADDITIF (FAP) TROP FAIBLE
NIVEAU ADDITIF FAP TROP FAIBLE
NIVEAU CARBURANT FAIBLE
NIVEAU DE CARBURANT FAIBLE
NIVEAU DE LIQUIDE LAVE-VITRE INSUFFISANT
NIVEAU D'HUILE MOTEUR A VERIFIER
NIVEAU FAIBLE DE LA BATTERIE DE SECOURS
NIVEAU LIQUIDE LAVE-GLACE INSUFFISANT
OUBLI CEINTURE CONDUCTEUR
OUBLI CEINTURE DE SECURITE
OUBLI CEINTURE PASSAGER ARRIERE DROIT
OUBLI CEINTURE PASSAGER ARRIERE GAUCHE
OUBLI CEINTURE PASSAGER AVANT DROIT
OUBLI CEINTURE(S) AV !
OUBLI CLE DE CONTACT
OUBLI FEU DE POSITION
OUBLI FREIN A MAIN !
OUVRANT(S) OUVERT(S)
PIED SUR LE FREIN ET LEVIER EN POSITION 'N' NECESSAIRES
PILE TELECOMMANDE 'PLIP' USAGEE
PLAQUETTES DE FREIN USEES
PLUSIEURS PORTES OUVERTES
PORTE ARRIERE DROITE OUVERTE
PORTE ARRIERE GAUCHE OUVERTE
PORTE AVANT DROITE OUVERTE
PORTE AVANT GAUCHE OUVERTE
PORTE LATERALE DROITE DEFAILLANTE
PORTE LATERALE GAUCHE DEFAILLANTE
PRESENCE D'EAU DANS LE FILTRE GASOIL
PRESSION HUILE MOTEUR INSUFFISANTE
PRESSION PNEU A VERIFIER
PRESSION PNEU A VERIFIER ET REINITIALISATION A EFFECTUER
PRESSION PNEUMAT. NON SURVEILLEE
PRESSION PNEUMATIQUE NORMALE
PRESSION PNEUMATIQUE(S) INSUFFISANTE
PRESSION SUSPENSION DEFAILLANTE
PROJECTEUR(S) DIRECTIONNEL(S) DEFAILLANT(S)
RECYCLAGE D'AIR HABITACLE ACTIVE
REGLAGE AUTO PROJECTEURS DEFAILLANT
RESERVOIR CARBURANT MAL VERROUILLE
RISQUE DE COLMATAGE FAP
RISQUE DE VERGLAS
ROUE(S) CREVEE(S) DETECTEE(S)
SYST. CONTROLE MOTEUR DEFAILLANT
SYST. D'AIDE STATIONNEMENT DEFAILLANT
SYST. FREINAGE (ABS) DEFAILLANT
SYSTEME ANTIPOLLUTION MOTEUR DEFAILLANT
SYSTEME CONTROLE VITESSE DEFAILLANT
SYSTEME D'AIDE AU STATIONNEMENT ARRIERE DEFAILLANT
SYSTEME D'AIDE AU STATIONNEMENT DESACTIVE
SYSTEME DE CONTROLE DU MOTEUR DEFAILLANT
SYSTEME DE FREINAGE DEFAILLANT
SYSTEME DEMARRAGE MAINS LIBRES DEFAILLANT
SYSTEME ESP / ASR DESACTIVE
SYSTEME ESP DESACTIVE
SYSTEME ESP/ASR DEFAILLANT
SYSTEME GPL DEFAILLANT
TELECOMMANDE NON DETECTEE
TEMP. HUILE MOTEUR TROP ELEVEE
TEMPERATURE BOITE AUTO TROP ELEVEE
TEMPERATURE MOTEUR EXCESSIVE
TEST LAMPES STOP: FREINEZ LEGEREMENT
TOIT OUVERT
VERIFIER PRESSION PNEUMATIQUE
VERROUILLAGE DES PORTES EFFECTUE
VITESSE ACTUELLE EXCESSIVE
VITESSE ELEVEE
merci de corriger et/ou compléter :2:
message d'origine :
Je pense qu'il serait intéressant de connaître toute la liste des messages qui peuvent s'afficher sur notre ODB, qu'il soit de base ou RT3 voire RT4, peu importe.
Quelqu'un a-t-il cette liste ?
Sinon, on peut faire un récapitulatif de tout ce qu'on a eu, mais ça risque de ne pas être exhaustif.
par exemple :
VERROUILLAGE AUTOMATIQUE DES PORTES ENCLENCHE
ALLUMAGE AUTOMATIQUE DES PHARES ENCLENCHE
ACTIVATION ESSUIE-GLACE AUTOMATIQUE
ANOMALIE BOITE AUTO
PORTE DROITE OUVERTE
PORTE GAUCHE OUVERTE
merci de corriger et/ou compléter la liste :2: (je remettrai tout ça dans l'ordre alphabétique)
Contact :
Re: liste des messages qui peuvent s'afficher sur l'ODB
sur le RT3 les messages sont differents. Voici les premiers qui me viennent à l'esprit.
RISQUE DE VERGLAS
PORTE LATERAL GAUCHE OUVERTE
PORTE LATERAL DROITE OUVERTE
PORTE LATERAL GAUCHE DEFAILLANTE
PORTE LATERAL DROITE DEFAILLANTE
Contact :
il écrit po porte gauche ou droite ouverte mais affiche une tite voiture :lol: (enfin sur la mienne, je crois)
pi ya aussi pour le coffre
et le niveau carburant faible
Contact :
exact, il faut ajouter
CAPOT MOTEUR OUVERT
COFFRE OUVERT
Contact :
Moulagaufre a écrit :il écrit po porte gauche ou droite ouverte mais affiche une tite voiture :lol: (enfin sur la mienne, je crois)
moi aussi mais quand tu commences à rouler porte ouverte le message s'affiche.
Contact :
ha ok, désolé, po fait gaffe (en même temps, c'est rare quand je roule les portes ouvertes... :lol: )
nouvelles idées :
allumages des feux désactivé
Contact :
j'ai mis le récap en tête de post.
Date de fabrication : 10 octobre 2007
Contact :
Moi j'ai eu celui-ci:
"SYSTEME DE CONTROLE DU MOTEUR DEFAILLANT"
Mister 1007
Kilométrage : 5000
Contact :
Message par Mister 1007 »
Et moi celui là : CONDUCTEUR DEFAILLANT :12:
Contact :
Ouais, on est pas loin que ça arrive ce genre de message, genre : VOUS VENEZ DE PERDRE 4 POINTS
jbc31 a écrit :Moi j'ai eu celui-ci:
OK, rajouté. Quel était le problème ?
Moi j'en ai un nouveau mais je ne sais plus le terme exact :
MODE ECONOMIE
MODE ECO ACTIVE
MODE ECONOMIE ACTIVE
ça vous parle ?
Contact :
A priori, le problème est peut-être toujours là, je l'ai décrit dans le post: viewtopic.php?f=7&t=2067.
Comme il n'a pas fait froid depuis, impossible de savoir si c'est corrigé.
Contact :
Ok, Gesan a séché, je sèche, il ne nous reste plus qu'à demander à David. Je vais lui demander de regarder ton topic de près pour voir ce qu'il en pense.
Contact :
Pour les messages de l'ODB ou pictogramme tu as
le radar de recul
le MP3
l'émission de radio écoutée
(sur les dernières versions full-can)
par contre je crois que sur les dernières version on a pas le message des ceintures mais juste les pictogrammes en bas de l'ODB.
Contact :
c'est marqué "latelal" au lieu de latéral pour les portes. :oops:
Contact :
Ok, corrigé. Vous confirmez l'apparition du mot "latérale" dans le message ? Car pour les portes avant et arrière ça parle de capot et de coffre. Les portes ne sont donc que forcément latérales. Mais bon.
Contact :
je parlais juste de la faute d'orthographe, le reste, je sais po :)
Contact :
Il n'y a pas le mot latéral ou alors j'ai pas fait attention aujourd'hui en ouvrant la porte.
Contact :
ce mot apparaît peut-être que sur les RT3 ou RT4.
Contact :
je vais verifier demain sur mon RT3
Date de fabrication : 15 novembre 2005
Contact :
Ben... c'est pas marqué dans la notice ?
Contact :
non, ça serait trop simple
Date de fabrication : 21 octobre 2005
Kilométrage : 64895
Becquet de toit
Par-choc peint couleur caisse
LEDs tabelau de bord bleues
Contact :
Moi qui ai eu de nombreux problèmes de porte, je peux vous le dire.
Sa marque : "porte avant droite ouverte" sur le RT3
J'ai vendu ma 1007 :(
Contact :
et quand la porte est defaillante, il n'y a pas le mot lateral ?
qui veut mettre sa porte en defaut pour voir ? :mrgreen:
Contact :
Ph3niX a écrit :Moi qui ai eu de nombreux problèmes de porte, je peux vous le dire.
Ok, je le rajoute, mais pourquoi parler de porte avant droite alors qu'il n'existe pas de porte arrière droite ?
A mon avis ils ont fait du copier coller de 307, 206 ou C3 sur 1007 et C2. Le RT3 n'a pas l'air de savoir que la 1007 est une 3 portes. :shock:
N'hésitez pas à me confirmer les messages que vous lisez, aujourd'hui j'ai corrigé de moi-même "verrouillage automatique actif" en "condamnation automatique des portes activée" :oops:
Kilométrage : 64895
Becquet de toit
Contact :
J'en est bien l'impression... Ils ne se sont pas beaucoup foulés à la sortie de la 1007.
Equipement électronique d'ancienne génération, apparemment copie de logiciel d'autres véhicules...
Certes se ne sont que de petits détails, et dire que Peugeot veut changer sont images pour être plus "haut de gamme"... Il y a comme une incohérence !
Répondre
Qui est en ligne ?
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 4 invités
